- Jul 15, 2008
So far there's been no reply in the main thread in diyaudio so I bring the question over here. Hope someone can enlighten this for me.
http://www.diyaudio.com/forums/group-buys/156149-tube-i-zator-professional-pcb.html
In short I'm sourcing parts and I'm not sure which value for the Rk I should pick. Lampizator said he chose 39R, while someone I know who built the DAC-end with similar output stage told me to go with 100R. But what I really want know is based on what formula or equation can you get the correct value?
My DAC is the Buffalo es9008, in the manual it says that
I'm thinking about picking the 6n2p or the 12ax7.
Thanks for reading.
The differential output of the buffalo is 0.924*1.65V (3.1746 Peak) + 1.65 DC bias and the series output resistance is nominally 195 Ohms at each output.
Thanks for reading.
