spurxiii
- May 18, 2013
Its a personal thing in terms of fit and comfort I believe, but for me they are the best comfort and SQ after trying all the tips (that fit me) in my possession. They don't last that long so I'm having to make one up every couple of weeks but its easy to do and costs almost nothing. The hole I made was tiny, I used the smaller screw driver I could find (the ones to open up watches etc) to poke the hole. It takes about 10 seconds to put on. It takes a bit longer to expand than complys though.
Oh I see now thanks a lot! How do they fit? The gr07 nozzle is a little bigger so was it hard to get them on? Did u have to make the hole bigger? how does it compare to the stock ear tips (in sq and comfort)?
thanks
