Head Injury
- Sep 11, 2009
I established that, jasonb. Power is multiplied by 10 for every 10 dB. That's 2x for every 3 dB.
10 dB is twice as loud, not 3 dB. 3 dB is twice as much power, which isn't twice the perceived volume.
Good point. Sorry.
How I learned this is that if you have a trumpet playing at full volume and then add a second trumpet playing at the exact same volume, you will see a 3dB increase. As per Head Injury's post, this is a doubling of the power (i.e. 2 sets of lungs instead of 1), but will not sound twice as loud. Thanks for the correction, Head Injury.
Thanks for taking the trouble.
I'll have to do a bit more reading to understand sensitivity ratings on headphones..
Also... will a 130db 500Hz tone be more painful/damaging than a 130db 30Hz tone?
You may want to check this link for more
Interesting question, Blue Boat. I did study this once upon a time, but I'm a bit rusty these days. My understanding is that the damage will be identical in it's scale because the damage is caused by the physical trauma of the sound waves belting your auditory systems. I don't think the physical power of the sound waves changes with frequency. That said, it could be possible that the different wavelengths somehow have different destructive power.
It could also be slightly influenced by the natural acoustics and resonance of your ear structures.
I'm sorry for bumping an old thread but I was lent these headphones and I searched them up and found their frequency response graph. I apologize for the cans not being high end but I just want to know what the graph says , as in in audiophile terms which I am unfamiliar with like recessed/rolled off.
http://en.goldenears.net/en/files/attach/images/254/062/012/375826b4d44e394a80b3d653baf3e474.png
I apologize once again for being a newb and appreciate it if the terms could be explained to me. Thank you.
Higher frequencies mean more energy.
It's always hard to be 100% certain from frequency response alone, but the graph suggests a warm sound with bass and mid-bass emphasis (the raised part to the left. The dip towards the right would suggest possibly recessed high end or it might just sound smooth. I definitely wouldn't expect analytical or harsh tendencies.
Is that what you're asking? Hope it helps.
That is exactly my point, that's why i'll never declare a pair of headphone, too bright , too bassy, uncomfortable etc..., and i always try to mention things like ''in my opinion'', ''i believe'', ''i think'', wich basically means on my sound system and according to my taste, they're are simply too many factors that come into play to pull any definitive conclusions regarding headphones, or any other components for that matter.
I take everyone's opinions with a grain of salt, and i encourage peoples to do the same with mine as well.
Happy listening.
