right now, it reduces it to a hum/buzz with faint radio, If I twist the cables around my interconnect, it gets faint but still noticeable. If I move my hands within 10 inches of the speaker cables the hum gets louder, ultimately resolving some radio signal when I hold them.
My interconnected is shielded but the speaker cables are not, it's the monoprice one that's thick and rigid.
IF I place the speakers farther apart, the buzz gets louder leading me to believe that they are acting as an antenna and feeding back into the amp, perhaps hinting to a ground crossover between the input and the output?
ok one more thing, if I just plug in speakers and no input now, there is loud buzz and radio, but when I take the interconnect(not connected to anything, not the amp, nor an input) and place one end a couple inches away from the speaker cables, the buzz is reduced to a hum. Best is if I stash it under books and stuff along with the slack from the power extension and the amps power cable.
And now if I connect the interconnect to the amp and hold the other end, buzz gets really loud, if I take the interconnect and put it adjacent to the power plug where the extension in plugged, it gets fainter
