marozie
- Feb 6, 2010
I looked up "allergy to epoxy resin" and found this article on DermNet NZ (NZ as in New Zealand):
Allergy to epoxy resin
Epoxy resin is a chemical that is part of an epoxy resin system. Epoxy resin systems are used widely in industry because of their strong adhesive properties, chemical resistance and toughness. Common two-part epoxy resin systems contain epoxy resin, catalysts/curing agents, and diluents and/or other additives. Any of these chemicals on their own may cause irritant and/or allergic contact reactions. Cured epoxy resin (the fully hardened combination of the epoxy resin system chemicals) should be non-irritating and non-sensitising.
What are the reactions to epoxy resin allergy?
Typical allergic contact dermatitis reactions may occur in individuals allergic to epoxy resin or other components of an epoxy resin system. The uncured epoxy resin, hardener and diluent are powerful irritants and potent sensitisers. Skin contact with the hardening agent may cause severe burns. They can also cause a severe allergic contact dermatitis characterized by redness, swelling and itching. Skin should be washed with soap and water if any contact occurs. In addition, hardeners and diluents are more volatile than resin and may cause allergic reactions from breathing in fumes. Cured epoxy resins are seldom a problem but it has been found that measurable amounts of uncured reagents may remain in the "cured" resin after 1 week.
So, as I guessed, the cured form of the epoxy shouldn't be hazardous, but the last sentence explains why I developed contact dermatitis.
