kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
I think it is explained partially on the website.
But here is how it works, a R2R ladder DAC has a pile of precision resistors, and a pile of switches
in the case of the soekris, lv595 which are serial in parallel out shift registers. The output stages of these
devices are designed to drive digital circuits, not resistors. As such they have definitely non-zero impedance.
And each of the 8 output stages (6 are used in the soekris per chip due to layout) do not have matched impedances either.
So if you really want 24 bits of precision with at least 1/2 lsb of accuracy, you have to do adjustments to get the
switches to have matched impedances. So you add trimming resistors to get things to be linear.
The question of long term stability (like 2 to 3 years later) is unknown.
silicon companies (like burr brown/ti) that make r2r monolithic parts do the same thing, they trim with a laser before they do the final packaging.
