Denafrips Ares II says this in the manual for example:I read this somewhere too. Do you have an example for which DAC this would be the case and do you also have a technical explanantion why that is so?
If you like via pm, as it is a bit OT here.
Thx
"(3) Analog Audio Signal Output Balanced output via XLR (pin2 hot), singled ended output via RCA. The Ares II is a true balanced DAC, we recommend using balanced output whenever possible. The RCA and XLR output are shared, please use either of the output at a time. It is not recommended to use both RCA and XLR output simultaneously"
I believe the issue is it messes with impedance matching. If the DAC has separate buffers for RCA and XLR, it's not an issue since each would only see the impedance attached to it.
