jlbrach
- Jun 4, 2005
not 2800 dollars worth
Try this one, looks like the endgame to me but still not cheap to me, not only the alloys chosen for the timbre, but the geometry is thought out to minimize distortionIf I purchase a $2800 IEM cable for my IER-Z1R like this one,will I notice improvement in sound quality in comparison to my IER-Z1R’s stock cable in my audio setup [Chord Hugo 2 (using optical) + SMSL PO100 Pro + MacBook Air (using Roon 2.0 software)] Also,can someone recommend a better IEM cable (or the best IEM cable in the world) than this one for my IER-Z1R?
that is quite an image you conjure upworth if you crap money from your anus
otherwise yeah i agree , 3K for a cable is laughing matter
It might get you to 30% of the performance of Abyss.not 2800 dollars worth
Isn’t IER-Z1R on the same level as Abyss? Are you saying that Abyss offers better sound quality than IER-Z1R? I don’t think that’s true…It might get you to 30% of the performance of Abyss.
The Z1R can compare to other IEM's and lower open back. It can't compete with the best full size offerings.Isn’t IER-Z1R on the same level as Abyss? Are you saying that Abyss offers better sound quality than IER-Z1R? I don’t think that’s true…
Oh…The Z1R can compare to other IEM's and lower open back. It can't compete with the best full size offerings.
I made myself a cable out of Cardas Golden Ratio 23.5 awg conductor, including direction, with Plussound gold connectors, and to be honest, I didn't like the sound. I read that their cables need to be burned for a long time, maybe the sound has improved over time, but more than 500 hours have passed and I still don't like the sound. The sound seems harsh, lacks fluidity, at first it sounded bassy and bright, over time the sound evened out, high frequencies are quite good for copper cable, but still it sounds too tight for me. I wonder if Cardas Clear Light cables are made from the same conductor.For anyone interested the Code 51 cable I bought last week from another Head-Fier is UP FOR SALE as I don't feel its the best pairing with my EVO which for me suits copper better. I find the treble a little too aggressive, for context it is also partnered with a Cayin N6ii DAP which is itself a lively player, I think the combination isnt right for me with the EVO. I think I made an expensive mistake as I had already read the recommendations not to partner an EVO with a silver cable, but I went ahead regardless. Should I part with the EVO, no doubt the Code 51 will be a brilliant cable for another top-tier IEM but I have no intention of doing that just yet.
Which leads me onto what to replace this cable with. I am speaking to DoctorJuggles about some options, and my initial thought was to look at the 4-Wire Cardas Clear Light cable he makes which is a clone of the 1960s, a cable reputed to work well with the Empire Ears EVO. I lean towards a warm, exciting, sound with good bass and away from a neutral sound. I wondered if anyone has heard this pairing, or perhaps cables that work well with the EE EVO that I should take a look at?
Cardas Golden Ratio, what is the conductor material and is it solid or stranded. How about your source and HP/IEMS.I made myself a cable out of Cardas Golden Ratio 23.5 awg conductor, including direction, with Plussound gold connectors, and to be honest, I didn't like the sound. I read that their cables need to be burned for a long time, maybe the sound has improved over time, but more than 500 hours have passed and I still don't like the sound. The sound seems harsh, lacks fluidity, at first it sounded bassy and bright, over time the sound evened out, high frequencies are quite good for copper cable, but still it sounds too tight for me. I wonder if Cardas Clear Light cables are made from the same conductor.
The wire is multistranded, copper litz, three different turns of different diameters in different directions, so it is called golden ratio, the wire is not flexible, my DAP and IEM in the signature https://www.hificollective.co.uk/hookup-wire/cardas/235awg.htmlCardas Golden Ratio, what is the conductor material and is it solid or stranded. How about your source and HP/IEMS.
Not sure but I have a Cardas Clear Light and it totally has the smoothness, analog and warmth mentioned.I made myself a cable out of Cardas Golden Ratio 23.5 awg conductor, including direction, with Plussound gold connectors, and to be honest, I didn't like the sound. I read that their cables need to be burned for a long time, maybe the sound has improved over time, but more than 500 hours have passed and I still don't like the sound. The sound seems harsh, lacks fluidity, at first it sounded bassy and bright, over time the sound evened out, high frequencies are quite good for copper cable, but still it sounds too tight for me. I wonder if Cardas Clear Light cables are made from the same conductor.
I didn't find a more suitable Cardas conductor, 23,5 AWG is perfect, the thinner one was only this one ( https://www.hificollective.co.uk/wire/cardas-265-awg.html ), without golden ratio and in polyurethane, which I didn't like. I don't feel any warmth with my version of the cable, the warmth can also be caused by a bad dielectric which creates electrical noise, with teflon cables I never felt any warmth, but teflon is too stiff for an iem cables.Not sure but I have a Cardas Clear Light and it totally has the smoothness, analog and warmth mentioned.
Regarding the cable you mentioned - it doesn't seem to be designed for IEMs at all, so the ergonomics will suffer. Too much for an IEM where it matters.
