Hifiman HM901R R2R DAC
Nov 10, 2022 at 8:53 PM Post #31 of 65
Hi Do you know how to remove the AMP card once it is installed? I am pressing down the small clamp on the side bit is not working.
You should press card until a click to install it.
Then press to move metallic holder and a card must go up and be like 45 degrees to your dap
Nov 12, 2022 at 10:40 AM Post #33 of 65
Hi do I have to press down this metallic clamp?
Nov 12, 2022 at 11:56 AM Post #34 of 65
It should hold your amp card in horizontal position. After you shift it (?just make sure that it’s not over the amp)- it won’t hold the card anymore and it will go up and after that you can extract it
Nov 27, 2022 at 8:27 AM Post #35 of 65
Is the 901R better than the 901S in sound performance?
Jul 14, 2023 at 12:06 PM Post #38 of 65
Jul 30, 2023 at 2:29 AM Post #43 of 65
warning - outputs on a balanced card with non-zero resistance, so headphones with a non-linear impedance change their tone a lot, for example, with monarch mk2 the sound is simply terrible - there are no high ones at all
Jul 31, 2023 at 9:13 AM Post #45 of 65
