Thanks for the response. You are right, apple uses them as M4A files, but .AAC is actually ISO standardized version of MPEG-4 that Apple and others adopted. (See Wikipedia cite below.) Apple calls them .M4A files, but they are the same as .AAC. Media Monkey, Windows Media Player, Etc.can all play Apple.M4A files (even just renamed with a .AAC extension) since they are really ".AAC" files.
FLAC is so superior and I'm moving there, but I have a lot of .AAC files that not part of my daily repertoire that I'd love to play on my oh--so-musical-Hifiman. Just was wondering if anybody has tried a .AAC or renamed .M4A>.AAC and gotten it to play. The specs on on the device says it plays .AAC. Thanks for your help!! (PS I believe AAC decoders are free so they can be included in any hardware.)
Advanced Audio Coding (
AAC) is a standardized,
lossy compression and
encoding scheme for
digital audio. Designed to be the successor of the
MP3 format, AAC generally achieves better sound quality than MP3 at similar
bit rates.
[2]
AAC has been standardized by
ISO and
IEC, as part of the
MPEG-2 and
MPEG-4 specifications.
[3][4] The MPEG-2 standard contains several audio coding methods, including the MP3 coding scheme.
