Hello, I am looking into buying the HiFiMan Focus-Pad. Would you mind sharing your thoughts for the Focus Pad? Why did you choose the Pad and not the Pad-a? Thanks!
Just bought the Focus pads for my HE-500's. Being perfectly honest I can't hear any difference between these and the the original velour pads that were on them. I can understand if people do due to the angular shape of the pads meaning they bear similarity to Audeze's where the sounds is more directed into the ear and thus less of the sound is altered by bouncing against the actual internals of your ear, but I can't distinguish a difference.
So for the ~$35 I paid to get them shipped from China to the UK you'd think I'd be upset, but mannnnn, these pads are the best upgrade ever in terms of comfort, for that alone they are worth the cost, they push against the head so much more softly compared to the original velour pads which had a bit of rigidity to them and wouldn't squash so much.
The surrounding velour also makes for a very soft touch against the side of the head as I think it distributes the clamping force better around the ear as they have a slightly more square shape than he velour pads which are semi-circular.
I think it's definitely worth it in the long run for those that are "okay" with the comfort of their current headphones but wouldn't mind them being a bit more comfortable.
Can anyone compare the modded Jergpads with the Focuspads, Focus A pads and Brainwavz angled pads on the HE400? I'm currently sporting the modified Jergpads (modulor's work) but wondered about the Brainwavz pads for when the Jergs wear out.
I did Jergpad v2.0 mod for HE400, and I'm highly impressed by sound. I previously used Shure SRH1440 velour pads just because comfort. I thought they weren't too much different sounding from original Hifiman velours, but overall I didn't quite feel sound was at it's full potential that HE400 could deliver. Now with Jergpad modded pads, I think HE400 are pretty close to their full potential of sound, not that I had experience of best-ever-setup with HE400, but to my ears HE400 are now on top of their sound, at least so far. Simply fantastic. Thank you Jerg for your work, I'm very satisfied with sound now.
No worries. As standard the HE-500s come with one set of pleather pads and one set of velour.
You can actually buy the focus pads from Hifiman's official store too (https://store.hifiman.com/index.php/focuspad.html) if you wanted to. I personally have bought them from Amazon and eBay before and they were both the same quality stuff.
Re: HE-500 I've got the pleather, velour, and focus, and none of them get used anymore after I came to realize the improvement using the Ether Flow Angled. Flatter frequency response, much better focus, wider and deeper soundstage. They are expensive for the 4** models but if your 500 is one of your go too's check it out.
Hifiman: https://store.hifiman.com/index.php/focuspad-a.html
I think the link was for some third party version, just not the real thing. The A pads have the perforated/mesh inside material which mimic the perforated interior ring on the Jerg pads.
These came on the very early HE 560 models. The pre-production ones with the real wood ring forming the body. Hifiman had worked with Jerg and the thought then was that those pads were mass produced knockoffs of the Jerg pad. They changed to the Focus pads for production. Then, due to popular request, they brought back the early pads as the FOCUS A version as an option.
