JaZZ
Because of its low efficiency and its price, it probably won't be on my upgrade wishlist, but I remain open minded as to how it will sound.
FTFY
Thanks John777!
I use the stock cable in the HEKv2 and it seems fine to me with no microphonics and it's very light. It seems flexible enough; I don't notice any excess stiffness. Just my 2 cents.
Currently have HEK 1000 V2 and a QP1R DAP capable of storing over 400GB of flac files. I like the sound but not enough power to drive the HEK often requiring max volume on high gain setting and clips. So added a iFI micro ican SE. This is a transportable amp with amazing power for a small device and can drive the HEK to higher volumes and has a bass boost switch. Unfortunately, it needs a wall outlet
With no built in battery. This combo sounds good for now as a transportable set up while away or moving room to room on my home but wanting to hear what others have come up with as their best transportable stack, for these cans at any price? The Mojo DAC has rave reviews but not sure can drive the HEK to high enough volume without another amp. Much more expensive DAPS also seem limited with an additional amp further adding to a bulky stack for mobility. I also want to be able to stream the likes of TIDAL eventually when away from home on vacation. Please tell me what options are out there to really get the most out of the HEK. THANKS
Mojo and Hugo do an excellent job driving my HE1000 effortlessly. Hugo 2 looks even more promising. HE1000 and DAVE are an end-game pairing in my book, but not transportable (just to show that power isn't an issue, since Mojo and Hugo don't have much less of it). If I were you I would wait for the Hugo 2. Or go for the «cheap» Mojo!
+1 for Mojo. It can drive my HE1000 very well although there were times when I felt that the bass is not as tight and rich compared to my desktop amps.
Haven't found the HEK to do well with the DAPS I've had, mostly the Pono (even got balanced cables for it...will work, but sounds much better using an amp). The MicroZOTL2 works great with the HEK, my go to combo (you look weird walking about in the world with the HEK anyway).
Having only just bought my HE1000v2, I was amazed at the SQ straight out of the box. And I can drive them direct from my iPad Pro if I don't want to switch my Moon 430HA(D) on.
