Just got them. Initial impressions (may change after some time):
*The HD800s I used were silver-recabled.
[size=small]Good:[/size]
-Excellent bass, in every parameter. Quantity is greater than the HD800, but a bit lower than the 600.
-Open, airy and delicate sound, especially treble (something I've noticed on the HE-5, LCD-2 and now the HE-6)
-Good dynamics (almost as good as the HD800).
-Good transient response and attack.
-Comfort is surprisingly good considering the ~500g weight (I'm sensitive to heavy cans...the LCD-2 were uncomfortable for sessions longer than 30 min)
[size=small]Bad:[/size]
-Too much treble around 8-14KHz, sounds bright and sibilant despite the treble quality.
-Not as transparent and revealing as the HD800.
-Midrange could use a bit more presence.
-Soundstage is flat and small, a far cry from the likes of the HD800. It's slightly smaller than the HD600's SS as well.
-The focus and placement of vocals isn't as good as the HD800.
-Build quality is a bit disappointing for a $1200 headphone.
-Difficult to drive well.
Overall, these are an improvement over the HE-5s, but the sibilant treble is somewhat bothersome. The treble might change with burn-in (if orthos burn-in at all), but it would have to be a more-than-subtle change to make me like it.
My initial impressions were with 0 minutes of burn-in or previous head-time. It has now been about 10 hours with mostly pink-noise playing and the sound has changed significantly (to my surprise, since the HE-5 I owned weren't affected much by burn-in). I've been comparing the HE-6 to the HD600 since yesterday to make sure it was actually burn-in and not just me adjusting psychoacoustically. They were freezing cold when I first put them on...not sure if normalizaing to room temperature was a factor.
The treble definitely died down from break-in. I'm hesitant to say that it decreased a lot, but that's certainly how it sounds. As a result, it feels like the bass increased. The midrange became more prominent too because of the subdued treble.
I think it might also be due to the pads, which have already changed shape from being on my noggin for a few hours.
So, the tone has changed considerably (now sounds somewhat like the HD600s), but transparency/detail remain the same. As of now, they're less fatiguing and much more forgiving than the HD800, but a bit slower (less damped) and less transparent. They don't reveal flaws, details or changes from gear swapping nearly as well as the microscope that is the HD800.
They have more bass depth and force than the Senns thought, and it can really rattle your skull with the right tracks, something the 800s will rarely do.
The soundstage hasn't changed but with more listening, I noticed it's better-layered than the HD600 and has the capacity to stretch beyond the limits of the 600s, though it still can't beat the 800 in this department.
BTW, I just want to repeat that the HD800 I'm comparing to are UPOCC silver-recabled and they sound noticeably different than with the stock or aftermarket copper wires. Silver makes them faster and bassier with more texture and impact. Copper was too slow, distant and laid-back for me.
Overall the HE-6 are pretty good. I like them, but not as much as the recabled HD800s ($1800 value).
