nc8000
$299 as I recall for the complete phone. Don't know if the headband can be bought alone
Hi guys!
It has been a while since I have T1. I'm using it balanced with nfb28 2015 H option. And I have nothing to complain about.
On the other hand, I always wanted to try He6. Especially as people praise it for its bass and how good it could be with rock/metal song. But I have had deep concerns about build quality of those beasts. I have seen many people have their he6's drivers replaced. Many have their cable replaced too. As I live in a country that using warranty from Hifiman is somehow impossible, I can't risk on having an unreliable product. My question from you is that how reliable do you think the latest production batch of he6 is? Do you think that they are as reliable as other flagship headphones like hd800 or t1?
I just wanted to reply to this old post of mine (about 8 months ago) and state that build quality is really an issue.
I have had he6 for less than 4 months.
Build quality is not on par with even 300$ headphone. I don't care about build quality as long as it doesn't affect my listening experience.
- Cable has been oxidized (near the head phone)
- They have used a subsidiary xlr socket brand that is a cheaper version of neutric connectors and it's a real shame for a 1300$ headphone
- The color of some metal parts that have more contact with my hands are fading.
- Most importantly, SMC connector is really ******** for headphone. I'm suffering from regular signal disconnection on left side. Although connection between cable and headphone is physically stiff. Whenever I move my head even the slightest moves make signal to be disconnected on the left side. Is there any chance that this regular connection/disconnection of signal hurt he6 driver and make it burn or something?
Regarding #4, I found that the connector on the left tends to unscrew itself...maybe something to do with using the headphone, putting it away, whatever I am doing with it in practice, even with aftermarket cables. I have tried to really tighten it up, and it seems ok lately, but I do find myself checking its tightness every now and then, like a nervous tick.
@jarnopp @heart banger-97
Simply twist the cable counter clockwise couple turns and screw the connector in while holding the cable still. They will never come loose after you do this.
Thanks for advice.
But, currently, connectors are not getting loos. Problem is that left driver is connecting/disconnecting all the time even with the slightest move.
HE6 Noob Question:
I just got an HE6 and am planning on driving it from the speaker taps of a Sansui 881....
Question is it better to hook them up direct to taps with no resistor or with a product like this?
https://www.moon-audio.com/hifiman-he-adapter.html
Peterek is making me a cable terminated in 4 speaker cables for direct connection,but just wanna double check before I blow my house up
Sounds like a loose connection inside the plug
WA5 is superb with the HE6. I am finding the Simaudio 430HA gives my WA5 serious competition for my HE6 listening time.
If the budget goes far enough to cover the 430HA it is a worthy contender for HE6 amping.
HE6 Noob Question:
I noted youbhave vio v281. Is he6 better with simaudio unit or v281
