Vintage Pioneer Spec amp was good for treble as well. Disclaimer - I'm never prone to hearing shrill or sibilant treble tho - loved the Pro900 and many say that is the epitome of shrill.
HifiMAN HE-6 Planar Magnetic Headphone
- Thread starter JIGF
NZtechfreak
- Jan 19, 2012
Questyle CMA800R... Also solid state. Also not shrill.
Yep, helps I guess that it is pure Class A.
Rockin_Zombie
Installed the Vegan pads. These are definitely the best velour pads I have seen, no wonder they cost so much (still overpriced though). I had Beyer and HiFiman velour pads before, both were so uncomfortable that I grew a dislike for velours in general. These are soft, plush, super comfortable. Somehow the weight of the headset is better adjusted with these pads too.
Now to the sound, the bass response is slightly better. What's definitely better is clarity, distortion is less with these pads.
Still need to listen more to see if it's an $80 worth upgrade. I will probably reach the conclusion that it is, since I have already spent the money. Actually the comfort alone is making me happy.
- Aug 2, 2014
Glad you're liking them so far.
ohhgourami
- Apr 16, 2010
Told ya!
borrego
- Jun 19, 2008
I have the SA-31SE, which puts 10W @40Ω. It drives all the Hifiman planars very well except the HE-6, which sounds shrill on it.
Power rating is not everything.
My NFB-27 built-in amp did a much better job with the HE-6, while being rated lower than the SA-31SE. It's the only instance where I preferred the builtin amp in the NFB-27 (balanced, of course) to the SA-31SE, actually (I loved the latter's sound character. The NFB-27 was colder by comparison).
I wouldn't recommend the smaller amps for the HE-6. Get a used Master-9 or the Reference 10.32 that's in the F/S if you can stretch your budget a bit.
Perhaps you should apply the "Laundry Clip Fix" to your SA-31SE I described in the amp's thread. The HE-6 draws much current, and the SA-31SE will sound "shrill" if the output transistors are not temperature compensated properly.
Comfort definitely. Sound stage too - larger. Clarity - not better than stock with unmodified vegans vs stock velours imo. There are trade-offs imo...
- Aug 2, 2014
That's why you modify them, lol. Do the felt ring mod and take it up to the next level.
Articnoise
I definitely prefer the Audeze vegans, but with what said and I agree with negura it comes with trade off in some aspects. The pros are IMO: Fuller bass, less high treble, better tonal balance, smoother overall sound and better image. The cons are IMO: a bit less overall clarity and less soundstage width.
Rockin_Zombie
I guess it depends on the kind of music you listen to, for rock/metal I definitely feel like the clarity is better with Audeze vegan over stock leather. The stock velour pads are terrible, I couldn't keep them on long enough to test whether those are better.
Articnoise
I guess I was not very clear. I have tried some different pads with the HE6 and the better clarity and soundstage width was with the Hifiman Focus pad A, not with the stock pads. The stock pads kind of suck.
TPSRA
I am curious, is it a improvement to remove the hair screen?
Irreversible, can't trail and error..
ohhgourami
- Apr 16, 2010
I remember there being slightly better clarity. I'll have to swap my pads to see. I have a pair without screens as you can see in that pic. It was brighter but maybe due to the reflections of not having felt at the time.
screwdriver
I like the hifiman focus pads also more than the audeze vegan pads
Jozurr
- Oct 25, 2009
Why do you prefer them over the Vegan pads?
Total: 13 (members: 0, guests: 13)
