money4me247
- Jan 27, 2013
The 400i has some emphasis in the upper bass (FR graphs won't show this), although it's very controlled so it doesn't sound bloated. The lowest bass rolls off slightly. There's also a big peak in the mid treble like the original 400, but it's not as annoyingly strong.
I like to think of the 400i as the 400 sound but a little grown up. The bass isn't quite as taught and impactful compared to the 400, but whereas the 400's point of most recession was centered around 4-5khz, the 400i has a secondary peak in that region (much like its bigger brother the 560), and it has a larger peak in the treble in the 10khz range like the original 400.
The 400i isn't glaringly v-shaped as the original 400, but it still holds near the same coloration-- ie a recessed upper midrange and emphasized treble. The original 400 is very vocal forward when it comes to male vocals, and its lower midrange emphasized (like the 400i) renders low brass and woodwinds dominantly compared to strings and high brass.
Compared to other headphones like the LCD3 and 560, the 400i is very much still v-shaped, but keep in mind that when I say that it's not to put the headphone down. It was the v-shaped sound of the 400 that made me keep it for more than 2 years.
I am curious how there can be emphasis in a frequency response that is not reflected in the FR graphs.
I disagree that v-shaped is the best characterization for the HE-400. There is definitely a bit of coloration, but he-400 definitely has a different sound signature compared to traditionally considered v-shaped sound signatures like the ultrasone pro900, beyer dt990, ath-m50, vmoda m100s, or pioneer hdj2000. (from my experience).
