It's because of their sensitivity. The headphones aren't broken, they just are a bit harder to amp than most. I had the same issue when I used to have the PRO4AAT's a year or so back.
I would check all my connections and if that does not fix the issue I would try the cans in a different amp/source. Lastly I would try another set of cables. BTW have you reseated the tubes and swapped them to see if the "dead" channel switches?
