Richiyaado
I was able to update the firmware OTA... took a while, though.
I have no idea what's been changed... I cannot find any info.
It is supposed to fix issue with Bluetooth AAC Playback stutters,, And Fixed issues with DLNA payback causing possible hangups,and can't play next track. (FYI, Deleted update files and will try OTA again...)I should have added that it took two or three tries before the firmware update actually downloaded via OTA completely (it would just turn off, and I'd start over). Then, when I checked again after it went off, it finally asked me whether I wanted to install the downloaded firmware, I clicked OK. Then, it went into some sort of installer mode with progress bars and restarted. Then, when I clicked on 'about', it shows I now have version 1.4.
I still don't know what they've changed, though. No info that I can find.
Followed similar steps, update via OTA failed (file seems the same size when I replaced on microSD, but it was causing vv_failed at every reboot), manual update went fine.Just upgraded to v1.4. No problems encountered.
- Using a 2GB microSD card, FAT32 format
- Containing only 1 file, r3pro.upt
- Copied file into microSD via a USB card reader
- Installed using System settings>>Firmware update>>Via SD-card
FYI: Tried updating from a 4GB FAT32 MicroSD, and no success. Attempt to install fails exactly the same as OTA.. And as when updating from downloaded r3pro.upt file on larger microsd card with my music on it. Have no idea why some of us are unable to update. Even did factor reset, and tried to update from 4Gb card, and still does not install V1.4 . (That was also the suggestion from Hiby on their facebook page.) Assume that by MANUAL update, you mean updating from the microsd card? Just checking if there is another (3rd) way to update.Followed similar steps, update via OTA failed (file seems the same size when I replaced on microSD, but it was causing vv_failed at every reboot), manual update went fine.
This solved also the problems I went into with firmware 1.3, when my device was updating several times or freezing every time I was powering it on. I tried to shut down and power on several times, and seems to work fine now. I hope this will last and I can finally enjoy the player
I found the regular to add too much warmness to the sound and overall color the sound, while I found the saber to be much cleaner and more neutral in terms of not affecting the sound.I’m confused as to what Pro version to buy...The Saber has supposedly more single ended power output, so I’m leaning towards it over the regular Pro version, but is the sound too clinical? I’ve found no direct comparisons between the two, just that the Saber is touted to be more analytical...
Still on the fence on what Pro model to buy since I recently bought the ATHMSR7bs which is supposedly really detailed and treble oriented, so I’m wagering that it won’t pair well with the Saber. But! But! I also own the Meze Noirs which is notorious for being bass heavy, making it on the other hand, pair really well with the Saber, unlike the AT’s. So, Head-FI, which one to buy?
And no, I’m not buying both Pro versions. Lol.
Oh and can anyone recommend a reliable 2.5mm male, 4.4 female adapter from Amazon? My AT’s will come shipped with a 4.4 balanced cable, so it won’t pair directly with the Pro. The Fiio adapter isn't on Amazon based on my searches.
