jobert
Hello I recently got some KZ ZSN Pro IEM's (0.75 2 pin); however, I don't want to have to have a dongle to use them on my Android phone I need some help finding a USB-C cable that would work well with them I have tried both the:
CVJ V6 (https://www.aliexpress.com/item/100....order_list.order_list_main.29.1e0b18020ETw1L)
CVJ V5 cables (https://www.aliexpress.com/item/100...o.order_list.order_list_main.5.1e0b18020ETw1L)
but I found they both had large amounts of static and noise while using them I believe this is because the DAC in them is not so good I have tried to browse the forms for some cheaper end cables that maybe able to solve this issue but I cant find any so I'm making a post to ask what are some of your suggestions as I'm not very knowledgeable in audio equipment I have looked at buying some:
HAKUGEI Rice litz 6N (https://www.aliexpress.com/item/100...lgo_pvid=7a4663b8-4092-49ad-a898-18fce6043244)
but they only do them in 0.78 2 pin and I don't want to risk damaging my new IEM's I would love some suggestions for cables that are £40 or less I would prefer modular cables but I know these can cost more
TL;DR
recently got some KZ ZSN Pro (0.75 2 pin)
want a USB-C cable replacement with good DAC
would prefer modular but not pickey
around £40 or less
TL;DR
around £40 or less
