Fuzziekiwi
- May 20, 2012
I've decided I'm going to buy an amp soon. It's for home use only on my desktop. I currently have a cheap soundcard (http://www.newegg.com/Product/Product.aspx?Item=N82E16829102003) which actually does improve the sound a bit. I'm planning to use the amp with my V6's and will be buying a pair of Koss ProDJ100's too.
I've heard that amps make a huge difference with the ProDJ100's. I'm going for something under $70, not too expensive as I'm young and do not have a job. So which would be better, and is it worth getting an amp? The E7, E10 or E11? I'm leaning towards the E7.
