gabsonuro
- Jan 8, 2013
I need help with an amp. I have the opportunity of getting a Little Dot MKV for 160$ used. the only problem i have, is that im not sure if ill be able to use it with my Xonar STX. (using the stx as a DAC, and the little dot as the amp.) I am not sure if it is possible, maybe go RCA to RCA into the amp? or go to 3.5mm to rca from the line out? would this have any affect on the sound quality? thanks.
