Flagger
- Dec 19, 2004
Some hair has snuck in to the front of the driver and is causing the infamous Grado rattle.
Looking for some advice on how to get the driver/transducer out of the plastic housing of a MS-1. Had no problems getting the back cups off with the hot water technique. But I cannot get the driver out using both techniques listed at http://gilmore2.chem.northwestern.edu/projects/showfile.php?file=grado_prj.htm.
It seems it is really glued in to the inside/front housing.
