project86
- Feb 21, 2007
I've been out of the game for a while when it comes to universal IEMs. I normally only listen to customs (due to fit issues with most universals), though I do try to spend time with big releases like the HiFiMAN RE2000 just to gauge performance levels. But for normal listening, it's custom or nothing these days, so I'm fairly out of the loop.
So I need a bit of help here.
My wife has very small ears. I mean, tiny. 99% of the IEMs she has tried just won't fit. Anything from mainstream brands like Audio Technica, Sony, Westone or Shure, don't work. Any earbud style won't fit either. Even the old HiFiMAN RE400, which is quite small for my big ears, sticks out in a weird way. We also discovered that the Etymotic and Klipsch models with deep insertion will technically fit, but won't stay very well, and aren't comfortable at all.
We tried dozens and the only possibly matches were little models like the old Q-Jays and UE700. But they didn't stay very well during active use, which is the whole point for her. Sennheiser IE8 and related models are ok but she needs over-the-ear cable routing, and their little add-on piece for that is terrible.
We eventually discovered that the RHA MA750 works pretty well for her ears. It's the round body and nice earhooks that work together - not even the smallest IEM, but certainly smallish, and it seems to do the job better than anything else. She has almost zero volume in the concha area so even the excellent/small RHA T20 is a no go.
Basically looking for something similar to the MA750, because those won't be around forever. The only thing I can think of is the Dita Answer which is quite similar to MA750 but with an angled nozzle. But it doesn't have integrated earhooks, and frankly is too expensive for her intended use.
What else should I be looking at? Remember, none of the "universal" versions of CIEMs will work (even the small ones like the old Noble prior to switching to metal bodies). But there must be other stuff out there...
