[HELP] Mi HD Pro replacement: Philips Hi-Res Audio PRO6305BK Vs. Pioneer Hi-Res Audio SE-CH3T
Sep 5, 2020 at 2:25 PM Thread Starter Post #1 of 4
Nikhchan
IND
Hi all,
So I had been using Mi HD Pro earphones for some time. It was just perfect for me. I am not much into bass stuff. I like granular and clear sound.
And Mi Pro HD probably had the perfect sound, BUT the durability of wires left a lot to be desired. The wires kept breaking and splitting.
SO I am looking elsewhere. I am limited by budget for time being to these two options:
1) Philips Hi-Res Audio PRO6305BK
https://www.amazon.in/Philips-Hi-Res-Audio-PRO6305BK-Headphones/dp/B07Q33B1LF
Acoustic system
Closed
Magnet type
Neodymium
Voice coil
CCAW
Speaker diameter
12.2 mm
Sensitivity
109 dB
Diaphragm
Mylar dome
Frequency response
7-40,000 Hz
2) Pioneer Hi-Res Audio SE-CH3T
https://www.amazon.in/Pioneer-Hi-Res-Audio-SE-CH3T-Headphones/dp/B079ZVM8GX
Acoustic system
Fully Enclosed Dynamic Headphones
Speaker diameter
5.5 mm
Sensitivity
102 dB
Diaphragm
Graphene-coated micro-driver diaphragm
Frequency response
8 -40,000 Hz
I want earbuds that can give amazing granular and clear sound like Mi HD PRO.
Now I don't have any dedicated DAC or hi-res music device. I just use my Phone ASUS Zenfone 5z With Hi-Res Audio of 192 kHz and 24 bits , DTS-X support (I turn it off).
I use Neutron Player with its insane upscaling on all audio to 32 bit and 786 kHz.
