Phloodpants
- Apr 9, 2002
I recently finished an amp I dubbed "Phonehenge". Taking a couple design cues from Sheldon Stoke's design, I designed an amp on an octagonal base. The base is made of cobote wood with bloodwood corners.
It's based on the BUF634 chip, along with an OP275.
I'm really proud of the way it looks and it sounds terrific!
(this pic is from before I mounted the controls and jacks)
But it hums!!
Now, I had suspected this might be a problem from the beginning, so before getting the whole thing assembled, I tested the circuit out. Everything was kosher. No hum, no noise, nada, zip! Last night I try it out and it hums pretty badly. Then I take it to work with me and the problem is less, but it's still there. If I turn on a flourescent light, it gets worse.
So basically, i think what happened is the day I tested it, the power was unusually clean to my house. Today it is noisier and the problem rears it's ugly head.
So it's picking up hum from the transformer, which is mounted very close to the op-amps and input circuitry.
I've tried bypassing the volume control entirely, and that doesn't have any effect.
I've also tried running power right to the transformer, bypassing the fuse and power switch. No difference.
Anybody have any more ideas? I would hate to scrap this project and put it in a plain project box! I'm out of ideas...
Hmm... what if I put a resistor on the input to lower the input impedance?
But it hums!!
