lubczyk
- Mar 11, 2012
*I know there are threads on this, but they all:
1. seem vague and don't have direct links
2. require some do-it-yourself work.
So I just received the Q40 and I'd like to have replacement cables on hand. I'd like direct links as suggestions, if you please.
I've heard that monoprice 3.5mm cables fit, but which ones? The same with Amazon cables. Are there any threaded replacement cables?
Will these work?
http://www.amazon.com/gp/product/B007CZNS0U/
et cetera....et cetera.
Will these work?
