Breaker
- Jan 15, 2013
Due to the discount I have at bestbuy, I've accounted for a higher price range if bought from there. I'm currently looking at the Sennheiser Momentums, AKG K550, Audio technica ATH-ESW9A, and Monster Inspirations unless something else is suggested. I considered stretching the price range for the Denon D600 but the opinions on here are quite spotty and don't seem worth the price. I currently have the ANC Inspirations as I won them, however, I'm considering selling them and purchasing other headphones.
I'm a bit of a basshead but I like clean bass and I don't want it drowning out the mids and highs.
I listen mostly to r&b and hip hop. I sometimes listen to techno and some acoustic tracks. I will also use the headphones for a decent amount of computer gaming.
They can be portable or more of home-use only, that isn't an issue for me as long as they're over ear headphones. I'm not a fan of on ear.
I've been using the VModa LP Crossfades for a little over a year but I'm looking for an upgrade, something a little more cleaner sounding that still produces good bass.
So basically looking for some insight on which route I should take.
