Adelz
- Aug 27, 2014
Hey, I'm planning on purchasing a pair of headphones along with an amp and dac. My budget is roughly $1000. I mostly listen to electronic music (Electro, House, Drum and Bass) and occasionally some Rock and Classical. The audio source will be my PC (Asus Maximus Gen3/Gene-Z motherboard with SupremeFX X-Fi 2 Built-in, if that's relevant).
Originally, I planned on getting the Sennheiser HD 650s along with a Magni and Modi. The HD 700s are in my price range as well. Would it be worth it to go for the 700s (with the Magni and Modi) or either the 600s or 650s, assuming I was to go with a Sennheiser brand headphone? Other than those, the HiFiMan HE-500s were also recommended to me, and any other recommendations are appreciated. As I have no first-hand experience with these headphones, I'm not sure which sound signature would be best for the type of music I listen to. I also hear that the 650s scale very well, so I'm not sure if I should go for those and get a more expensive amp like the Lyr or Bottlehead Crack.
Any advice is appreciated. Thanks!
EDIT: I purchased the Sennheiser HD 650s from BuySonic for $350. In my opinion it was a great deal and I think they'll be a great fit for me. I'm still deciding on an amp and DAC. Currently I'm leaning toward the Little Dot MK IV or Valhalla, however I'm not sure if it would really be worth the money over a Magni (most likely will all be paired with a Modi unless there are other suggestions).
