Originally Posted by bradman /img/forum/go_quote.gif
Feifan, oh cripes. That's not making it easier!
LOL!
I'm leaning a bit more towards the DT with it's preamp functionality, but responses like this are making it dificult to forget the idea of balanced. I better continue pondering the issue. Did you get the stepped attenuator on your DB?
Yes, the stepped attenuator for the DT-SE and the DTB. For the latter, it's included as part of the package deal, along with the HD650 + HR's balanced cable (and home DAC and home module).
If so, could you let me know how it compares to that on the DT? Do you have any difficulty setting it to the precise level you want to listen at?
They function the same, I think. I don't see any differences. Re volume levels -- it's really a non-issue because you have three gain settings: high, low, medium. For finer tuning, you can lower the gain and fine tune volume. For example, at high, I'm usually at 9:00; at medium, at 12:00 or 1:00. With the wider range of volume settings in medium, you can find a setting that's comfortable. Ninety % of the time I leave it at high for the cans that I have. For value (whether you resell it or not), it's probably better to go with the best possible options.
Btw, if your DT and DB are located in physical proximity to each other, have you considered connecting the DB to the DPS as well?
Yeah, they're right next to each other. That's one of the first things I futzed with -- the PS connections. I found that the DTB raised the heat level of the DPS to a significant degree. When I switched in the Astrodyne, the DTB seemed to actually sound better. I'm not sure if this makes any sense since there's a huge price difference between the two. OTOH, the DT-SE didn't sound as good with the Astrodyne. Again, I don't know why this is so. So I have them set up the way I do: DTB with Astrodyne and DT-SE with DPS.
Re the DAC: Yeah, I always wonder if the max DAC in the DTB would make a big difference -- but only the home DAC is available. The same re the home vs. max module. If there's not enough room in the desktop chassis, I wonder if a larger case might be a consideration -- that is, IF the max is a significant improvement over the home. (EDIT: By "larger" I mean a little bigger than the DT but a lot smaller than the full-sized home and max.)
Re the inputs: three digital (optical, coaxial, USB) and two analog -- I'm using them all! It's sweet, it's fun. I'm strictly cans so I've never used the analog out. BTW, the USB straight off a computer is a killer in both the balanced and SE DTs. (I'm ripping tracks in lossless WAV -- huge files, but worth the SQ.)
