Elysian
- Aug 14, 2011
I love my primary listening rig, but I don't love having to turn on a transformer and letting the tubes warm up for an hour before I've reached my happy hunting ground.
Consequently, I'm looking for a decent headphone to use when I don't feel like dealing with my transformer, DAC, preamp, amp, and tubes (particularly given how I avoid turning my gear on unless I'm actually going to be listening to it for awhile, and I can't leave it on unsupervised for safety reasons).
The SR225i would actually fit my criteria pretty well but I've gotten tired of the Grado house sound and it's uncomfortable. I've washed the pads and have tried different earpad substitutes, but none of them feel comfortable.
Could someone please help recommend a headphone based on the following criteria?
- Less than $350.
- Will be powered directly through onboard computer analog out, so not a lot of power available (Realtek 889). (a cheap solid-state headphone amp in between, like the Fiio E6, is an option; none of the cheap solid-state headphone amps I've tried seem to add enough power, though)
- Comfortable. K701 is a good example of headphones that are comfortable to wear for extended periods of time.
- Decently clean bass (does not have to be boomy or loud), good definition in the mids and highs.
- Smoothness preferred over edgyness, even if it means sacrificing some detail. I can't stand grain.
- Colored sound is fine as long as it's not sibilant.
- Doesn't matter if open or closed.
- No IEMs.
- I'll be listening to mostly electronica, hip-hop/r&b, jpop/jrock/kpop, metal, rock, and gaming streams.
Some headphones I've been considering, but haven't had a chance to demo, are the Fostex T50RP and Hifiman HE-300. It seems like the T50RP is bad out of the box but gets much better after burn-in. I'm concerned that it needs proper amping, though. I am concerned that my motherboard won't be able to power either headphone well. The Sennheiser HD600 is out of the question, as, to me, it sounds thin and weak without proper amping. The Grado is a great example of headphones that work well without a power amp.
I actually kind of like the K701, except for how they sound overly analytical and lifeless to me. It's too bad as I like the K701's detail and bass, but something about the K701, through a subpar rig, gives me an uncanny valley effect when I'm listening to music.
Thanks for any suggestions. I'm also open to any cheap solid state amp suggestions to stick in between, like the Fiio E6, but based on reviews here, none of the sub-$100 solid state options look worthwhile. No tubes please. My main rig already has 20 tubes and I don't need any more!
- Less than $350.
- No IEMs.
