RevAmped
- Aug 10, 2011
More power means even less distortion, and all you are doing is adding a small device half the size of an iPhone which connects from your sound card to your headphones. It will not be a major change, because if you think about it, there are only four components in a setup; the source, the DAC, the amp, and your output. You have 3/4,and you are adding the fourth, and switching your output. The Fiio E11 will be the best for your current setup, it pairs very nicely with the ATH-M50s. If you decide to go no amp, the UE6000 will be a good option, and since they are powered, they are likely to need an amp much less than the ATH-M50s.
