bahamot
- Sep 17, 2005
After reading through several headphone amp spec, I found voltage, current, resistance and power are always mentioned on the specs. Any knowledgable head-fiers can enlighten me, which is more important amongst the metioned attributes?
For example, if the headphone amp is able to output to 4 Ohm headphones with maximum current 300 mAh. And it is stated that the headphone amp can output 2.88W/32 Ohm. If my headphone is AKG K701, can the headphone amp drive the K701? Why?
Thanks heaps.
Thanks heaps.
