- Mar 4, 2014
Tips don't matter beyond getting a good seal and having a hole the same size as the IEM sound bore. Use whatever tips you like best.
Power usage is roughly the same as my ER-4S. I can power both from a Sansa Clip without problems. A lot more power than your average IEM but the power requirements aren't insane.
Takes time to adjust to a different frequency response.
I forgot to add, YMMV
Regarding tips, I do feel a difference. No, I don't mean it in the miraculous kind of sound change. I mean it in terms of foam tips generally causing the sound to be more 'constricted', and the high frequencies to suffer. But I do agree, the key is to the bore size of the tips. And I would also like to add, that tip dependency extends further than just sonic changes. Fit comfort and isolation too, though I suppose that applies to all IEMs. In the case of the B3, from a design standpoint, a shallow or deep insertion will determine the B3 being 'flush' fit, or a 'dangle' fit. Not really sure how to explain this. Some like it, some don't. As with all things, it boils down to taste and preference.
Regarding power usage, I will have to hold my hands up and say: perhaps 'power' isn't the right word to use. Pardon my lack of technical knowledge for that. But in essence, finding the right amp and source matters. This of course, is down to my personal experience. I believe the best match for the B3 are amps and sources which don't add color, and don't affect the imaging of the B3. In other words, not tampering with the B3's signature sonic traits. Fiio amps generally do that, and I wouldn't recommend them for the B3. Keep in mind, I'm advocating making the B3 sound best, not saying drawing the line between the B3 sucking and/or sounding good!
