Darner
- Feb 17, 2014
Ah, that's not good. I was hoping the B3 would be my answer. The S4s have become such a PINA!
Thanks for your input analogsurviver!I have also XKDUN CK-M700 tips and none of them worked for me... It is clearly indicated on the page 8 of this thread that the results are for mebut supported by 3 different B3 users (may be more). As a result I have provided a message for the senn double flange tips on the bottom of the tip rolling page: "they may or may not suit but you should give a try". Thats only an advise. Your input is valuable since most people here dont indicate large earcanal fit issues.
It will be good to hear how they sound now?
I just discovered that currently they are not in my possesion. It means:
a ) I forgot them in a church when I was recording a live concert ( some 100 kg of equipment ...easy to miss 50 or so grammes of Havi case ) - monitored with Havi B3 Pro (Old Version)
b ) I forgot them at the local high end store I was having demo of the above recording (can ask tomorrow...)
c ) They are GONE FOR GOOD
Hope you can find them
I have to "make do" with the Stax Lambda Pro/SRM 1MK2 in the interim - and although the big Stax is better, Havi
is not THAT far behind. In certain ways, it might well be even superiour. And I can not compare them right now...
WOW
One minor criticism that springs to mind is at moments slightly grainy/grating treble - but it is a minor fault compared to mostly too dark or heavily peaky treble in most of the rest of IEMs.
Unless B6 proves to be B3 without the need to EQ the bass and even better treble ... - and yes, if it would be less power hungry, it would be even greater. But NOT at the expense of the ultimate SQ achievable.
I completely agree on your statements here. Exactly the same perception of SQ, but I find bass to be adequate for my tastes...
I am more than happy with this purchase. And they scale up with better sources -like K340 scales up with better amps-... So that's why I am also eying DX90 (and X5) now...
