My bughead emperor player won't recognize this dac but foobar does! Interesting.
Happy as a Pig in Schiit: Introducing Modi Multibit
- Thread starter Jason Stoddard
- Tags
- schiit modi multibit
I am having trouble with Mimby/Moby USB via picoreplayer as well. Same issue. Works sometimes. I think it may have something to do with the auto port selection on it. Is there a way to force Moby to stick to the assigned port?
Use a USB to coax converter and Mimby will always be on coax input.
KoshNaranek
I do use on coax. I was just playing
pkcpga
It's strange because Robb watt from chord recommends USB connection, so does Linn, naim and meridian. They state USB is more isolated and uses the timing from the DAC so it more accurate. So I found it strange with schiit everyone recommends the opposite.
That's because Schiit's first USB module literally sounds inferior to the Coax input. However, this has been fixed with their USB Gen 2 and USB Gen 3 module. Also the USB tech before didn't have asynchronous and galvanic isolation leading to brittle sound compared the Coax's natural sound.
Some users are nitpicky with the DAC input so the USB stigma is still very broad. IMO, today's USB implementation is just as good as Coax and maybe even more transparent than Coax. However, regardless of coax, optical or USB input, linear power supply, transport and cables to a lesser degree play a noticeable role in the system. A crappy transport will always result in suboptimal sound regardless if the input is AES/EBU, coax, USB or optical.
orphean
- Aug 21, 2016
Does Schiit's USB Gen 3 have galvanic isolation though? I thought it didn't for some reason.
droopy1592
- Jul 23, 2006
I will say I've owned 3 Schiit DACs Modi2U, Bifrost 4490, and a Modi MB, and every one of them has had some sort of issue via USB, using a Mac Pro, iMac, and a Macbook Air. I definitely stay away from USB, optical works the best for me. I have not tried putting a powered USB hub in the middle, I've read this will fix most of the issues.
And I've had modi 2u and went to mimby and had 0 problems with either. Not even one. 2014 MacBook Pro retina.
siwolfman
Schiit also offers the Wyrd which offers USB "decrapification". It lowers the noise floor and has a linear power supply.
siwolfman
The PS Audio LANRover offers galvanic isolation.
orphean
- Aug 21, 2016
Yeah I know other company's products do, I just didn't think Schiit USB implementations currently have it.
jamor
- Nov 28, 2013
So you don't need a coaxial for your modi for better quality anymore?
pkcpga
USB is more isolated so it shouldn't have a niose floor, the niose would come from the DAC conversion or power supply on either end, does this just isolate the information from its power supply? Most better DACs would have that built into them. So I guess it's separate with schiit?
droopy1592
- Jul 23, 2006
Ok I've been A/Bing the same songs with spdif vs usb for about four hours now and really can't tell the difference. If anything the optical sounds 0.01% smoother and that's really splicing atoms here.
fjrabon
- Feb 1, 2009
The wyrd is more for the non-Uber magni, which is USB bus powered. It isn't really necessary for any of heir other products. That doesn't stop people from buying it for Schiit's other products, because you know audiophiles.
mentt
- Feb 3, 2010
There is no reason to debate about PC or MAC. If you want to hear full potential of your DAC keep away from computers. Computers will never sound good and it is weakest link in your chain. Source component is the most important component of them all. If you want to hear what your DAC can sound like buy good streamer. Buy Sonore microRendu + Small Green Computer microJukebox and be done with that. DACs will come and go, but good source component will stay and you will never want to go back to PC or MAC for music reproduction.
