kaiwei
- Aug 2, 2001
Hi all,
I realise that many people have trouble getting MAD to work at 24bit under windows 2000 or XP with the WDM drivers. This is a short set of instructions to getting it to work. I've a MAudio Delta Dio 2496 but it should work with all 24bit soundcard.
1) Download this file
http://www.tonewise.com/www/wwwdrv.zip
Install as per instructions in it.
2) Enable your soundcard in the OUTPUT config box, ie for me it's the Delta Dio Multiclient
*Reboot if needed
3) Go to winamp, input, change MAD to 24bit, go to output, waveout, then change output device to your soundcard but (wwwarped).
eg for me I choosed M Audio Delta Dio M (WWWarped)
4) Play!
*IF YOU HEAR STATIC OR ELECTRONIC NOISE DO THIS
Under waveout, under advanced settings, change Maximum blocks to 32, Max blocksize to 16kb & Min blocksize to 4kb. I found that if I dun use these settings, I get the electronic noise.
Many thanks to the author of wwwarped!
*Reboot if needed
4) Play!
