Hi there, I'm Lewis
I recently got into the audio hobby and I'm happy to be a part of this community of experts and other people who share the love for the hobby. I haven't made an introduction on the forum for that as I am desperate to get help from people on this site asap!
Please read the following,
I have a fiio k3 2021 dac/amp which connects via usb-c to usb-a into my pc. When using the 3.5mm and 2.5mm outputs on my DAC/amp there is no interference at all.
I bought a pair of Mackie MR624 active speakers > https://www.gear4music.com/Recordin...-Powered-Studio-Monitor-Pair-with-Stands/2X1F
I use a 3.5mm to dual RCA adapter, priced at £11 and some standard RCA cables for L/R sound.
Before I get onto the issue heres the preface:
1 crucial part of understanding how I personally determined it was a ground loop problem was that when the dac was plugged into my ipad pro via usb-c to usb-c where the dac is powered by the ipad, all the nasty interference was gone so I knew it wasnt the cables or speakers.
I read the following two threads (you dont need to read these but here they are anyway) : https://www.head-fi.org/threads/how...picking-up-interference-from-computer.634541/
and https://www.head-fi.org/threads/computer-causing-hissing-in-yamaha-hs80ms.852093/#post-13535905
Forum no.2 was where I determined I had the same issues and decided to buy this which worked for someone else https://www.amazon.co.uk/AV-Link-Ground-Loop-Isolator/dp/B000NVWB9O
And it works! It completely removes the horrible interference from my computer. However it RUINS the low end, imaging and high end.. But at least I have diagnosed the problem!
So now I am at a loss. My two options (as far as I'm aware) are as follows:
1. Buy a new dac/amp that is powered externally through my extension cable and also splash £150-400 on it for endgame quality dac/amping. (I'd need one with a 2.5mm headphone balanced out or i'd have to buy a £30 2.5mm to 4.4mm balanced adapter which I am willing to do)
2. Buy a high quality ground loop isolator either for a usb port or for rca inputs+outputs
I'm glad to have a discussion but I would really like some suggestions as to what dac/amp to get OR what isolator to get (I cant find any isolators!)... As I am honestly clueless and as such not even sure option 1 would work. I'm presuming option 1 would work as my dac/amp isnt powered through the extension cable whereas dac's at that price range are?
Also I don't have any space to work with. I have a 6 extension cable in my room and thats it. So i can't power a dac + amp, it would need to be an all-in-one dac/amp.
Many thanks!
Lewis
Many thanks!
Lewis
