Originally Posted by HeadphoneAddict /img/forum/go_quote.gif
The NOVO is acting like a wire with gain (WWG) in your setup, so it will sound just like your source. Funny how everyone says that is what an amp should be (WWG), and then when it doesn't sound different than your iPod or CDP that is a bad thing.
Ah, but we're forever being told that an amp is required to drive the 'phones properly.
Therefore the
expectation is that the improved control of the headphones will improve (or at least change) the sound, regardless of the quality of the source. If this doesn't happen, the conclusion is that source could drive the headphones well enough.
My
opinion:
This, I think, is where synergy comes in. The (integrated) source really needs to be considered as signal -> amp.
An amp cannot improve a signal, it can only limit the extent to which it is degraded while driving a load. So, if the signal is not great (poor slew rate etc.) it may be that the integrated amp can replicate this while driving the load (HP). The external amp when fed the same signal (line out) can only match the integrated amp.
Only with a better signal, will the differences in amplifiers become apparent.
So, the conclusion that the source could drive the HP well enough is half right. It could drive them well enough for the signal it produces.
You therefore need to find a better source to separate amps and only when you can separate them will you know the source is better!
Does that make sense?
I'm still not entirely convinced by this myself when it comes to high impedance headphones. These surely require larger voltages and especially so for percussion hits (slew rate again). So, the difference with an external amp vs internal, 3-6V amp must be obvious, no? Can the signal really make that much difference?
