eclipes
- Mar 8, 2011
I highly recommend the Little Dot I+, LD IV is good but not as good as the I + for Grados. If you have other headphones to accommodate then IV is ok. LD I+ puts 800mW into 32ohms
compared to 100mW from the LD IV
Congratulations on the new found Grado goodness.
Make sure you pick an amp that excels with low 32ohm impedance. A few on here love the Little 1+ which does well with
the Grado range. LD IV only delivers a max of 100mW at 32 ohms, it excels at 120 ohm/300mW and above.
