devouringone3
Yep I was aware of it
"Black - Martin Custom Cup w/ comfy pads
Red - Stock Grado Cup w/ comfy pads
Purple - Liberated SR80i Driver."
There's almost no (significant; we need to account for headphone placement) difference between Martin Custom wooden cups and Grado SR80i cups, except at 2 to 3 kHz, and the liberated drivers also act the same as with the cups starting at 3.5 kHz.
With the HD800 the mod happens between the drivers and your ears; with Grado the driver is at the front most and the mods happen behind it, for that reason I think it would be less effective... though I don't want to discredit the impact of a good Grado mod.
I didn't said "cups vs. no cups" would be hard to tell apart, or that modding and damping didn't influenced sound. I want to express that I think material for the cups (wood/metal/plastic) changes very little; and that the geometry itself, I'm not as sure, though as long as the air chamber behind the driver remains unchanged (geometrically), that there's a free cylindrical column of air for the sound to pass through and a fully open back to get out, sound shouldn't change either. (For example if you make your cups jumbo and wooden on the outside, or if you increase the length of your tube, there would be no change occurring on both the sound produced and perceived.)
If you line the tube with Creatology foam I agree it can change the sound a little bit yeah, because you're making an "obturation", closing the aperture, and I think drivers are quite sensitive to that, even if it accounts for very little in the final volume.
Stuffed cups will sound stuffed, I think it's a principle behind damping, right?
I do hear that shoutiness/glare you're referring to... I will experiment with non-taped pads and see if my SR100-0 and SR325-0 also have the same problem, it will tell if it is really coming from the HP-1000 cups, or from any Grado cups (the drivers?).
I'm a driver fatalist, I think it's one responsible for both the qualities and the flaws, when the headphone is fully open. Sennheiser, Beyerdynamic, Audiotechnica, Stax, Koss, and more, I don't think they ever damped any of their cups will smooth materials the way Grado and T50RP modders do it.
Not perfectly flat waves all going in the exact same direction but spreading in a similar pattern to the surface/relief of the diaphragm:
But still relatively planar and piston like.
but you're assuming that the sound waves are propogating in one direction like a column with no outward movement. But they are expanding outward and bouncing off the interior walls of the cups.
purrin did some tests on this matter, measuring SR80 drivers in different cups with or without foam plus with no cup at all. that's what led him to try the HP1000 foam mod to see if the ringing at 2 kHz could be reduced. The cups on grados make a difference. the material, the diameter and the length. Coating the inside of the cup with a damping material does affect the sound. the damping is the key factor, not the diameter change with the material since that change is minimal and the effect that is seen on the HP1000 is very specifically a damping issue. some excess energy is now absorbed by the foam.
It's the same concept used on the HD800 foam damping mod to drop the treble region down a bit. different targeted frequency but similar materials and outcome.
