obobskivich
Those woodies are absolutely hawt - are those 325s or Alesandros in those shells?
Anyways, I haven't heard the PS-500, but I found the 325's treble un-naturally bright to begin with. FWIR (like Focker's comments) the PS 500 are less bright/aggressive compared to their siblings - FR graphs seem to show a similar trend. But what you're describing with the jumbos/bagels/GSK pads on the 325s is what most people describe as happening to their Grados (apart from the GSK/PSK) when mated with those pads. I don't think there's much to be done while retaining the sound as it is now (remember that pads play a big role in the sound of a headphone); what's your issue with them as-is? Comfort? Fit? etc You might actually be able to happily get away with the comfies (the pads the SR-60 have) since the 325 are brighter; I tried them on my 225s and it just killed the top end too much, but I'm imagining if the top were boosted up a bit more, it might just balance out nicely (or at least be a nice enough compromise). They're also a lot cheaper than bagels to try.
