Got $4300US for a 6 port power strip?
- Thread starter geek707
castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
![aDDbVKZ_460swp.jpg aDDbVKZ_460swp.jpg](https://cdn.head-fi.org/a/11787952.jpg)
Doug2507
The "results" crack me up...![Beyer Smile :beyersmile: :beyersmile:](https://cdn.head-fi.org/e/headfi/beyersmile.png)
Not too shabby at joinery tbf, bet they'd make a good looking rack!
13A UK Fuse
How about £3, 800 for a 13A fuse, it could blow the moment you switched on your washing machine and you'd have to buy another one.
71 dB
Well, it has got "Quantum Science" in its name so it has to be amazing! I wonder how much the high voltage power lines and transformers in between the power plants and our homes 'bottleneck'? We demand Silver Quantum Science power lines and transformers!13A UK Fuse
So insane!
Doug2507
This. I'm glad I live in the UK where all you need is a decent 13a fuse sat inside an MK plug!Well, it has got "Quantum Science" in its name so it has to be amazing! I wonder how much the high voltage power lines and transformers in between the power plants and our homes 'bottleneck'? We demand Silver Quantum Science power lines and transformers!
So insane!
gregorio
- Feb 14, 2008
I liked this bit:
“All internal parts are tightly fit by clear, slow-curing epoxy resin which results in the widest, clearest soundstage …”
Great audiophile epoxy resin, what next? As it’s slow-curing, does that mean it needs burning in?![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
G
G
bfreedma
The Hornet!
- Feb 3, 2012
I liked this bit:
G
Slow cure helps bass and soundstage. Fast cure helps treble and PRAT. Obviously
Next question - what color does the epoxy cure to? Dark for Black Backgrounds, or Clear for that super treble above 30000hz
Last question: Is the epoxy cryoed?
Doug2507
Absolutely. Burn in service also available but varying results...![Fire :fire: :fire:](https://cdn.head-fi.org/e/nature/fire.svg)
Andrew_WOT
- Jan 18, 2004
Did you see their burn in guide?
https://www.lessloss.com/docs/Burn-In_Curve.pdf
Bytor123
- Apr 6, 2013
I've got two of those
I swear that's how my brain works every Friday afternoon.
oakparkmusicguy
Did they cancel each other out? ![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f602.png)
bigshot
This is a great power strip, but I have a problem. My system has seven plugs. Can I daisy chain two of these?
gregorio
- Feb 14, 2008
Yes, and your music will sound 2x betterer!Can I daisy chain two of these?
G
