I originally planned on working the META42 design to its full potential by using a very good power supply, and choosing finest of parts under the belief that this approach would improve the sound to a higher level. I have not heard the gilmore amp, however based on information and opinions from people I take into consideration, I'm willing to go along with the suggestion that it is the better amp design. I felt at the time that perhaps this high performance configuration of a META42 may reach or go beyond the level of the gilmore amp. Further thinking lead me to go with logic instead of my stubborness. So with that idea, I told myself, audio is SO worth all this money. Instead of getting a hot rodded META42, I've decided to put that effort into the accepted better design, gilmore.
Is the gilmore a significant upgrade from a well configured meta42? Probably not, however, there probably is a level gap, and these sublties often make all the difference...
Whit, have you done a comparisons between those four power supplies you mention? I'd be very interested in your findings and opinions on the strengths of each one. What makes the POOGE the best? Do they all use different regulator chips? Are they completely different designs? What do you think is the best transformer for an audio power supply?
