greenkiwi
I have had this problem too.
And never had it with other dacs.
As stated above, once every few weeks i may have to cycle power pr restart the computer but I don't view it as a big deal.
I think I'll be moving on to a yggy sooner rather than later
Yeah. And I have some ether Cs that are shipping now.
That will mean I have to save up again.
As promised, I just want to update you guys since I've been using the Infinity since Nov.2015. I have USB connectivity issues since the very first time I plugged this into my laptop. In the beginning, I installed the LH 2.29 driver and then plugged the Infinity into my laptop (X220/win7/foobar+wasapi) and foobar would give me unexpected error problems. Luckily the 3.26 driver came out so I installed that instead and power cycled the Pulse. I got things to work eventually and just kept the Pulse playing 24/7.
Last month (Jan2016), my friend came over to do a little comparison with his Audiolab M-DAC. I noticed that when I was switching headphones (DT990/HD650) between the 2 DACs caused the Pulse to buzz/crash/die. Unplugging headphones from the M-DAC I can hear a click which I assume shuts down the circuit preventing any shorts while plugging headphones into the Pulse causes it to short out. I was simply unplugging headphones from the M-DAC and plugging it back into the Pulse. I would need to power cycle the Infinity a few times to get it working again.
A few people are staying this week so I shutdown the Infinity to move it to another area. Once I turned it back on and connect it to my laptop again, Foobar gave me the unexpected error then a timing error message. This also required multiple power cycles to get it working again with foobar again. I then proceeded to plugging in my HD650's and realized there was no sound coming out until I adjusted the volume knob. I also noticed a click so I scrolled through the menu and found that somehow the digital filter went from FTM to FRM. I've always left it on FTM so somehow this thing resetted itself.
I'm really not sure what kind of testing so called professional reviewers etc are doing but really sitting down and using this thing has revealed that it is very finicky. People can say what they want about Benchmark/Mytek/Audiolab but I've personally used those feel those are all more reliable than the Pulse. Simply put, the Benchmark/Mytek/Audiolab all feel like a reliable tool and the Pulse feels faulty/finicky. I simply need to cross my fingers hoping it works again if I power cycle it.
My use cases aren't very difficult. The setup is an Infinity+LPS+LS 2G connecting to a Thinkpad X220 (8gb/240gb SSD) running win7 64bit+foobar (wasapi/asio).
1.) I expect the DAC to work when plugging it into my laptop after plugging in and handshaking with my laptop (LH control panel recognizes it) but foobar coughs up unexpected/timing error messages and I need to power cycle it multiple times until foobar works again
2.) I expect the DAC to work when plugging in headphones but somehow it randomly causes a buzz and crashes the Pulse necessitating multiple power cycles again.
I'm not someone that makes a big fuss out of nothing but my real world usage has shown me that this thing isn't very reliable. I have friends that would also agree with me and that includes the Vi DAC (IR sensor overheat so remote doesn't work if more than 1m away etc).
I'll be opening up a ticket to see what LH says.
Have you tried using a different audio player like VLC or JRiver to see if you get the same behaviors? There is a possibility it could be an issue with Windows and/or Foobar.
I have VLC but I don't use it for music. I could try it next time. When I power down and up, the Pulse handshakes, shows up in the LH control panel but under foobar (DS, wasapi, asio) doesn't work until I power cycle a few times. Hard to believe it's foobars problem since other DACs work fine and my dragonfly has never skipped a beat (foobar/wasapi) since I got it in 2012. I'm willing to test this a bit more as I want to figure out what is the problem as well.
Now the other thing that surprised me is the apparent 'short circuit' when I plug in SE/unbalanced headphones. The Pulse was powered on/working and just buzzed/died/crash however you want to put it when I plugged in a set of SE/unbalanced HD650/DT990. I can only guess that it's a design decision/fault somehow for the argument of sound quality. But I can tell you that no matter how many times I plugged/unplugged these headphones with the MDAC (music playing/not playing), there was never a problem since I can hear it click when unplugging the headphones to prevent any shorting I assume.
In case anyone is wondering, the headphones (HD650/DT990) themselves are not defective and works with the MDAC/dragonfly no problem.
Are you using any adaptors, or aftermarket cables when connecting your headphones?
I had a 1/8" to 1/4" adaptor that caused short circuits when connecting my iem's to my Pulse. I tried another of the same type (different brand) of adaptor and it worked fine.
