xSkinny
- Mar 7, 2014
BUMP
This is all I can think of at the moment. Any question feel free to ask. I recently upgraded my headphones, but will keep the AD700X - It is a very decent headphone.
For me not long after I put them on - maybe half an hour. I think it is meant to be a loose fitting headphone, and being so light, if it fits your head I'd imagine it being a very very comfortable headphone, but alas just doesn't fit me like that.
I've not had many other headphones so can't advise on others. I did have a SteelSeries Siberia prior to the AD700X. That is a more tighter fitting headphone, but after about an hour or so gaming, my ears hurt due to it pressing on them.
I'm not trying to confuse you, but when I first tried the AD700X from the Siberia, the ATs were sooo comfortable. Not to mention sound quality being on another level - But given the price difference this is to be expected.
Despite the headband fit issue and other negatives I listed earlier, I wouldn't hesitate to recommend them to you. It's actually these headphones that got me really interested in audio equipment. I could go from gaming to listening and appreciating music. Sound quality in this sense gives them a broad appeal.
The loose fit can be worked around if needed (I think a DIY fix involves just 1 rubber band). There probably will be other headphones that do aspects better, but at the price, broad usage I feel they punch above their weight, and a solid choice.
Personally I've been using the Philips X1's with the V-moda mic and its been fantastic!! The X1's are great for any type of music and some of the most comfortable headphones if not THE most comfortable I've ever owned or tested! The best part about them is that they have a detachable cable that is very standard and can take any 3.5mm to 3.5mm you throw at it so no need to mod or stick mics on them. Personally they will stay with me for a long long time because of how flexible and comfortable they are. Its hard to describe the sound. They are basically a jack of all trades. They don't lack or excel in any ONE area but top to bottom do everything really good!
I also like my M100's with the deeper XL pads but the X1's being open and more comfy have pretty much taken over as my gaming set.
Thanks,
It would definitely have been nice to have pivoting cups. That would certainly help with comfort. But to be honest after buying the headphones, that didn't jump to me as an issue until I read/saw reviews mentioning it. The main issues I have already mentioned.
I would add, the fact that the drivers are angled, and the headphones are themselves at a slight angle may help mitigate any issues (if any) with the ears not being parallel with the headphones.
I washed the earpads of my AD700X for the first time yesterday, so you can have a closer look inside, Worth noting, the ear pads are very very fiddly to get back on the headphones, I haven't managed it as yet
Well, I'm glad I was of assistance to you.
Let us know your feedback after burning them in. Have fun!
Ha nothing to worry about. Just means breaking them in. Headphones tend to 'open up' and their sound develops or matures (gets better) as you continue to use them. I suppose it's like any mechanical instrument. Some say it's just the imagination of the listener, while others say it's actually mechanical - in that the wire coils in the drivers gradually change or tighten (or something like that lol) once you put electricity through them
I recently got a new headphone along with a DAC and amp, and I think I can perceive a change in the sound from when I first listened to them. With my AD700X I found myself enjoying listening to the same music more and more as time passed.
Ah, I see. So how long do I want to break them in for? And can I just leave it playing on my computer over night or something?
