Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Or just skip the so-called burn-in process and just enjoy your headphones. That works too.
Ok one last question then I'll stop. I've read countless glowing reviews of the D7000's, yet they are still inferior to the HD650's and Akg 701 because they are closed? If so, why are they twice as much, especially when they are fairly noisy for a closed headphone, i.e. it would be rude to listen to an ipod with one in public. This makes no sense to me.
It would be ridiculous to listen to them in public for more than just the amount of leakage...and their fragile nature...and cumbersome cable.
Anyway...why are they inferior to the 650s and K701s...? Their bass is far superior to both of those headphones and IMO the D7000 bests them in every way except sound stage.
They're more comfortable, top notch bass, second to none comfort, gorgeous design, and easy to power...and they isolate better than the other 2 if that's necessary. People overstate how 'bad' it is. They're nowhere near open. At the fairly loud levels I listen people may hear something at 3 - 4 feet away. No further and not enough to tell what you're listening to.
http://reviews.cnet.co.uk/headphones/denon-ah-d7000-headphones-review-49299396/2/
I was basing that off this review. Maybe this review is a joke though?
I found your review to be very informative btw.
The 840 is not much of an upgrade from the M50. If you're playing around at the same price point, go for something with a different sound like the Grado or maybe an Ultrasone (HFi580 and 780, bassy and more balanced respectively)
Ultrasones can be hit or miss from some people, depending just how the S-Logic interacts with your ears.
I personally preferred the MS1 to the SR80 (and SR125), but the differences are so minute you'd really only be able to tell if you A/B'd them directly or were already very familiar with the Grado sound. For most people, I recommend getting the cheapest one available and doing a couple of mods.
So just let me ask, which is the better bang for the buck? MS1 or SR80i? Or is it simply subjective?
wondering if there any full size headphone that sounds like the beyer DT1350?
