I have both. Although it's close, I'd go with the Superlux for superior, if imperfect, sound quality over the HM5.
However, if isolation is important to you and you don't mind big cans, the HM5 will be your pick.
If sound stage is important, the Superlux wins.
Tight budget request here. I'm tossing between buying a pair of Superlux HD668b with AKG K240 velour pads (total cost: £42) and a pair of Studiospares M1000 (Seemingly a rebranded FA-003/HM5. Total cost: £59). Which of these would you recommend, or are there any other UK based Head-fiers out there who know of something even better?
I use my headphones for pretty much everything. The main requirements that I have are that they must be fairly easy to run, fairly neutral, and suit a large variety of music (Ranging from Piano to Metal and pretty much everything in-between).
