LFF
Co-Organizer for Can Jam '09
Member of the Trade: Paradox
- Dec 6, 2004
I have no idea how I missed this thread. I own the 21 CD EMI set, some of the Larry Walsh discs from 1987 and some of the Bob Norberg remasters you can find in the stores. FWIW, the EMI set is probably the best version of the albums you can find on CD and the only set I recommend to people wanting to buy Sinatra's Capitol Years output. I believe there are three concepts box sets - one in 1991 (done by Larry Walsh), one in 1994 (done by Bob Norberg in 20bit) and one in 1998 (also by Norberg but now done in 24bit). AVOID THE CONCEPTS BOX SETS REMASTERED BY BOB NORBERG!!!! Both Norberg sets are overly processed with bad EQ and too much noise reduction and echo.
The sound of the EMI set is clean and it is not over processed. They all seem to be sourced from the EMI master dubs (dubs of the masters held by Capitol) which is both good and bad. Good because EMI didn't over process or NoNoise them like Bob Norberg did for the Concepts Box Set. Bad because they still got some things wrong with a few of the albums and because the tapes are at least a generation down from the actual masters.
It's sad how my favorite album - Songs For Swingin' Lovers - is also messed up. It sounds very similar to the Larry Walsh remaster but just a tad dryer. That album should have no echo on it. It is obvious that the source tape was the post 1961 master with added echo and what not.
Here is what it should sound like.
Notice how dry the recording is and how different it sounds from the CD releases. Very little echo. Sinatra's voice also sounds more life-like.
All of the CD versions, including the MFSL, were sourced from the bad tapes. All vinyl post-1961 is also sourced from the bad tapes. If you want to hear any other song from that album and how it should sound, feel free to ask and I'll post another clip.
The best way to hear Songs For Swingin' Lovers is from an original 1950's west coast gray label vinyl pressing.
There are better versions of all of these albums but you'll have to resort to vinyl to get the better versions. As far as CD's go, the EMI box set is the very best.
Regardless, I feel this set it the best set for the Capitol Years material on CD. If you want to hear what the master tapes sound like buy this CD. It has some of the best sounding Sinatra you will ever hear.
The Columbia set you got is SUPERB! I have yet to buy it but I have sampled a few of those CD's and they sound wonderful. Considering the age of the recordings, the work they did on the Columbia set is top notch.
As for his Reprise years, the suitcase set and the plain box set both feature the same mastering. Only the packaging is different. The sound on the Reprise set is also a little off at times but it is no slacker. A set well worth getting if you can find one.
Just my 2 cents.
Originally Posted by jsaliga /img/forum/go_quote.gif I just ordered this imported (EMI International) 21-CD boxed set with all of Sinatra's Capitol Records releases. Amazon.com: The Capitol Years: Frank Sinatra: Music I know that Capitol released its own boxed set called Concepts. Most of the reviews I read seemed to indicate that the EMI set was a bit better. I picked it for that reason and the fact that it is still in print and the Capitol set has been discontinued. I was wondering if there are any members here who own the EMI set and would care to comment on it. I'll be happy to add my own thoughts once my set arrives. Thanks. --Jerome |
Just my 2 cents.
