tj28
- Dec 8, 2011
What would be a good open headphone to complement these, sub-$300? I was thinking the K712.
Beyer, Senn, HiFiMan, AKG, ... so many options. Best would be to specify what exactly you want from the headphone (sound signature, use for what genres, ...) and then to audition some of them to pick your favourite - or just go ahead and buy all of them.
I do not really think, you would gain anything with any sub-$300 open headphone over X00. In $5-600+ category maybe, but not sub-$300.
+1 to the HD600
+2 to the HD600.
I own HD600s and TH-X00 and they compliment each other perfectly. The HD600 naturally has the larger soundstage, slightly more transparent.. as in sounding clearer. The TH-X00 is a better jack of all trades. The HD600 lacks subbass and is more suited for vocals, acoustic, classical, live instruments -- but it does that best.
The TH-X00 I listen to just about everything else with... rock, hip-hop, EDM, dance, pop, synthpop, 80s music, Prince... etc.
You will be happy owning both, I would be sad if I only owned one of them.
The Purpleheart should be fun to try out and compare with the E-MU Teak, TH-X00 Mahogany, TH-X00 Ebony, TH-900 and any version of the TH-6XX series.
Good times... :bigsmile_face:
Did you just collected all those seriously ?
