Beagle
His body's not a canvas, and he wasn't raised by apes.
- Jun 29, 2001
Ed Harcourt
件名:TH900 MK2
ご連絡ありがとうございます。
フォステクス・サポートチームの佐藤と申します。
ご質問頂きましたTH900mk2につきましてご回答申し上げます。
TH900とTH900mk2のドライバーは同一の物で違いはございません。
TH900mk2で変更になりましたのはケーブルが着脱可能な方式になったことと、
別売のバランスケーブルをお買い求め頂く事で、バランス接続にも対応でき
る様になったことです。
よろしくお願いいたします。
Subject: TH900 MK2
Thank you for contact us.
My name is Fostex support team of SATO.
I would like answers for questions received TH900mk2.
The same thing in the TH900 and TH900mk2 drivers are no differences.
And changes in the TH900mk2 had become a removable system cable and
Purchase a balanced cable (sold separately) to the balanced connection is also available
I was like that.
Best regards.
And Fostex dare to sell it at more than twice the price of the current one?
I was like that.
I'm looking to replace my Denon D5000 with a Fostex TH900 or TH900mk2. Do you guys think that the TH900(mk2) is a worthy successor of the D5000?
In short, yes. I owned the D5000 for a while before the TH900 and there's a good improvement. Bass and sub bass is increased, and it's a lot crisper and tighter. The D5000 may have a bit more warmth due to the treble characteristics on the TH900 which are strong - I personally don't mind this.
I've modded mine with cables, dampening on the inside and Lawton leather pads.
You can see here the frequency response curves and responses to various tests like impulse and square wave:
D5000:
http://www.innerfidelity.com/images/DenonAHD5000.pdf
TH900:
http://www.innerfidelity.com/images/FostexTH900.pdf
You can see that the square wave response of the TH900 is very tight and indicates a strong, clean/crisp and punchy bass. If that's what you want, you'll get some of the best bass response from any headphone I have used.
The mids can seem recessed to some depending on the genre of music and other factors on the TH900; it won't be as "flat" as the D5000 - this is really mainly because the bass and treble emphasis is strong on the 900's and the mids are therefore less blended. However, with a proper tube amplifier or tube hybrid the TH900 opens up beautifully and the mids warm up (that's the benefit of tubes; their warmth in the mids) -- plus the natural bass characteristics of the TH900 complement this very well. You just need to be careful picking if you use tube amps since these are low impedance headphones, and you don't want the dampening factor - or basically the output impedance of the tube amp to be too high otherwise it will be noisy. They're also just very easy to drive in general so you can play around with DAC's and Amps with no issue of "lack of power." But you can get quite loud because they have a respectable 1,800 mW driver load capacity and a good 100 dB/mW efficiency.
The D5000 are flatter, more neutral, and the bass isn't nearly as strong, as you can see from the square wave response graphs I linked earlier. If this sounds like what you're after for an improvement, then the TH900 or MK2 (same driver, different cable options) will be a good choice.
$1499 retail. Order with us and get free headphones stand and free shipping. email info@wooaudio.com to order.
This is probably just the TH900 except with proprietary detachable cables.
It would be cheaper to just get a MK1 TH900 and mod it with Hifiman connectors. Seems like it would look better too.
